Roller Rockers
Old 02-28-2008, 02:01 PM
white94
white94's Avatar
Default Roller Rockers
Put a set of Comp Pro Magnum RR's (1.6) on as well as new springs. They are kind of noisey while running. How much chatter from these is to be expected?
white94 is offline
Old 02-28-2008, 02:26 PM
WhiteWindsor
WhiteWindsor's Avatar
Default RE: Roller Rockers
I've got RR on my non-roller 357. They will be noisier, maybe not as noisy as mine though. Mine sound like sewing machine. Can you post a vid?
WhiteWindsor is offline
Old 02-28-2008, 04:14 PM
67mustang302
67mustang302's Avatar
Mine sounds like a sewing machine as well. The nature of the beast.
67mustang302 is offline
Old 02-28-2008, 04:41 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
did you properly adjust them with each lifter at the bottom of its movement, normally you tighten the nut by hand till the pushrod isnt loose anymore then turn it 3/4 of a turn
rmodel65 is offline
Sixer4Life
10-12-2015 04:26 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
uedlose
09-30-2015 08:01 AM
Sixer4Life
09-28-2015 07:05 AM
JDWalton
09-24-2015 08:47 PM
Quick Reply: Roller Rockers
