problem starting.
problem starting.
Today in the morningI sprayed my engine down with wd-40 to clean it..Right after i started my car and drove it for a couple of minutes and it was fine. then about 15 minutes later i go to start it and its just cranking..Im getting fuel, my battery and alt. are good...I got a new coil and its still not working...For about 8 months ive been driving with the tps sensor unplugged and i dont know if that has anything to do with it. And also the tfi-iv ignition module is missing a screw and im not sure if that can have anything to do with it......Any ideas?
RE: problem starting.
check all ignition connectors or start with the basics.. check for fuel and spark.. check for fuel by spraying starting fluid in the intake and see if it fires up..if not get a inline spark checker and see if you have spark at the plugs then to the cap from coil
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
