Rear gears
Old 10-11-2003, 06:29 PM
91GT
91GT's Avatar
Default Rear gears
<FONT face="Times New Roman, Times, serif" size=3>I was wondering if anyone knows what RPM I would be turnig at 60 or 70 miles an hour with a T-5 and 4:11 gears?</FONT></P>
91GT is offline
Old 10-11-2003, 06:32 PM
Mustang88LXKid
Mustang88LXKid's Avatar
Default Rear gears
that would be high, im not sure of the actual numbers, but the higher the gear ratio the higher RPMs. So if you are going to have a street car 4:11, thats not really "streetable" in my terms because your gonna have to use alot of gas and keep it at a high RPM to drive it. So thats my opinion on it, you'll be guzzling gas with 4:10 gears too and trust me it will be harder to drive.</P>
Matt</P>
Mustang88LXKid is offline
Old 10-11-2003, 07:08 PM
91GT
91GT's Avatar
Default Rear gears
Well I was going to drop a T-56 6-speed in it, and hopefully that would drop the R's enough to drive on the highway. If not I 'll go with 3.73's
91GT is offline
Old 10-12-2003, 12:47 AM
vfast
I ♥ Acer
vfast's Avatar
Default Rear gears
what is the gear ratoi on the 6th gear?...I'd say it would change....4:10 gear are a whole nother animal...because of the diff. pinion gears....they now make a 3:90 gear for the 8.8
vfast is offline
Old 10-12-2003, 07:09 AM
horatio102
horatio102's Avatar
Default Rear gears
go to randy's ring and pinion - they've got a few calculators for figuring out engine speed with a given mph and gear ratio. If you had a 1:1 5th with 4.10's and 35" tires I could tell you you're going to be turning just over 2000rpm at 60.
horatio102 is offline
Old 10-12-2003, 11:30 AM
vfast
I ♥ Acer
vfast's Avatar
Default Rear gears
5th is more like 0.68
with a stock tire 27in @ 60 it's like 2500rpm
vfast is offline
Old 10-12-2003, 04:48 PM
horatio102
horatio102's Avatar
Default Rear gears
Yeah I know 5th is a fairly low overdrive. But I've got a 1:1 top gear in my truck and 4.10's in the axles.
Old 10-12-2003, 06:36 PM
91GT
91GT's Avatar
Default Rear gears
The 6 speed has a 5th gear of 1:1 and the 6th gear is .76
91GT is offline
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Pyrate Dave
09-10-2015 07:30 PM
Roush05
09-10-2015 12:23 PM
Quick Reply: Rear gears
