real quick question......10 or 12 degrees for stock 302?
Old 03-07-2008, 04:25 PM
DoctorD415
DoctorD415's Avatar
Default real quick question......10 or 12 degrees for stock 302?
What mark should the timing light read on the harmonic balancer?
DoctorD415 is offline
Old 03-07-2008, 04:28 PM
Rajun_Cajun
Rajun_Cajun's Avatar
Default RE: real quick question......10 or 12 degrees for stock 302?
Stock timing is 10 degrees. Bump that chit up to 13-14 though!
Rajun_Cajun is offline
Old 03-07-2008, 04:31 PM
DoctorD415
DoctorD415's Avatar
y is that?
Old 03-07-2008, 05:08 PM
shaun8850
shaun8850's Avatar
you want to go fast dont u?
first thing i did on my car when it was stock
shaun8850 is offline
Old 03-07-2008, 05:26 PM
DoctorD415
DoctorD415's Avatar
alright, ya its around 13-14. Thanks.
Old 03-07-2008, 05:52 PM
tmuti13
tmuti13's Avatar
if you bump it to 13-14, you'll most likely have to run premium fuel.
tmuti13 is offline
tmajikman
tmajikman's Avatar
14 degrees is where my stock 5.0 is set at. Works well.
tmajikman is offline
Old 03-07-2008, 06:47 PM
Stella94GT
Stella94GT's Avatar
i can run 15 no problem at all, i use permium now tho.
Stella94GT is offline
Old 03-07-2008, 07:48 PM
nitrous_bob
nitrous_bob's Avatar
best is to run 87 octane on 12* if you can...read the plugs and power tune it at the track by mph
advancing timing makes hp, higher octane loses hp , so going high then using premium you might not need....negates the whole works
but stock is 10* to answer your question.... 10* btdc not 10* atdc
10-0 is atdc 0-20 is btdc
nitrous_bob is offline
Old 03-07-2008, 09:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
10 degrees is stock and bump from there to where it won't ping/detonate at 14 degrees you may have to run premium fuel
mjr46 is offline
carid
07-08-2016 09:55 AM
11-10-2015 11:39 AM
Pyrate Dave
09-10-2015 07:30 PM
mdj89
09-06-2015 11:08 PM
iamgobono
09-03-2015 12:37 PM
Quick Reply: real quick question......10 or 12 degrees for stock 302?
