car stalling/ backfireing
Old 03-24-2008, 05:20 PM
the gish
the gish's Avatar
Default car stalling/ backfireing
So I have a problem. My car is hitting some kind of fuel cut or its missing or something. I just was wandering if anyone else has this problem. It drives around fine untill you try to get on it then at just after 3000 rpms it falls all over itself, the motor cuts out some times it backfires but it always does it in gear not in neutral. But in first sometimes it cuts out if I try to gun it off the line. I have tried replacing the cap and rotor, plugs and wires but no change I don't know what to try next cause I don't want to just throw money and parts at it. Any advice.? My car is a 87 5.0 with a cam, mass air conversion and exaust if that makes any difference. Thanks
the gish is offline
Old 03-24-2008, 05:46 PM
WhiteWindsor
WhiteWindsor's Avatar
Default RE: car stalling/ backfireing
Is this car new to you? If not what have you done to it lately?
WhiteWindsor is offline
Old 03-24-2008, 06:00 PM
the gish
the gish's Avatar
Yah I have only had it about two weeks.
the gish is offline
Old 03-24-2008, 06:09 PM
Bullitt91
Bullitt91's Avatar
see if all of the wires for the MAF conversion are spliced correctly. make sure they are tight or not corroded.
Bullitt91 is offline
Old 03-24-2008, 06:25 PM
1992lx5.0
1992lx5.0's Avatar
have you checked the timing and the fuel pressure, and how do the plugs look, it sounds to me as if the timing is off where does it backfire threw the intake or exhaust???
1992lx5.0 is offline
Old 03-24-2008, 06:27 PM
1992lx5.0
1992lx5.0's Avatar
check your fuel filter as well
Old 03-24-2008, 11:31 PM
the gish
the gish's Avatar
It backfires threw the exaust but not every time. I'm gonna work on it tomorrow if anybody else has any ideas Im all ears. Thanks
the gish is offline
Old 03-25-2008, 12:04 AM
86foxybox
86foxybox's Avatar
how important is checking the fuel pressure on mustangs? is it easy to balance fuel and air?
86foxybox is offline
Old 03-26-2008, 12:11 AM
the gish
the gish's Avatar
Ok tried to check the fuel pressure today and there is some weird electronic sensor looking thing were the schrader valve should be. So Im goin to a local speed shop tommorow and see if they have something that will work. I think It's the fuel thou cause today I noticed that if you drive it right after starting it the car will let you get on it more but once you go throu about two gears it starts cutting out and hesitating. I have a question thou. How would the timing just get screwed up? It was fine for about a week and a half after I bought the car. Also Is this a interfearince motor or not? If my timing is off am I in danger of banging a valve off a piston or something?
the gish is offline
Old 03-26-2008, 01:09 AM
Deleted User
I ♥ Acer
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Deleted User is offline
djbigskrilla
09-20-2022 01:04 AM
chain
08-17-2015 08:52 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: car stalling/ backfireing
