Not running
Old 04-03-2008, 06:55 PM
  #21
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Default RE: Not running
Ok, wet plugs mean 1 of two things (in your case), way too rich or weak ignition system. I would go with a weak ignition system. Buy a new coil and see if that helps. You say you have spark for sure. How do you know that? Did you get the things to test it like Mjr said or you think you do because you changed the cap and stuff? If you don't have if yet try your coil and if that don't work go for the ignition box. Then if that doesn't fix it computer is next on my list.
BUT that is if you have checked all of your connections on everything and mainly your grounds!!!
projectresto83 is offline
Old 04-04-2008, 03:52 PM
  #22
Go Roush
Go Roush's Avatar
I replplugs and wires and then kept a plug out and turned it over and there is spark there. I did try the computer just for ****s and giggles, I had an extra sitting on the shelf and that did not make a bit of differnece. I will sure give the coil a try and see what happens. thanks
Go Roush is offline
10-07-2015 07:02 PM
heslekrants
09-23-2015 04:02 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
MusicCity615
09-12-2015 07:05 AM
uedlose
09-10-2015 03:30 PM
Quick Reply: Not running
