fuel gauge install?
fuel gauge install?
ok i currently have a mechanical fuel gauge with a isolator need to know if you just remove the schrader valve and install a hose to the fuel rail or would i need a adaptor? also on the isolator it has a bleeder screw what side is it for the gauge side or the pressure side?
RE: fuel gauge install?
The isolator allows you to run a hose filled with water to the gauge.....so there will be no fuel running in the interior of your car...
In other words, guage-->water hose-->isolator-->fuel hose-->fuel rail...
As fas as the schraeder goes.....not sure, I hooked mine directly up to my Fuel Pressure Regulator...do you have an aftermarket one?
im just going straight from the gauge to the rail. hopefully the track officials wont see this, not too worried about gas going into my car other than that reason, some with my oil pressure gauge.
ORIGINAL: ctgreddy
http://i242.photobucket.com/albums/f...inished002.jpg
yeah i was thinking of doing that but not sure how they'd look on an sn95. and im kinda afraid of people messing with them. i just hope i can take it to the track without issues. last year they never took a look at my car at all so i hope ill be good.
ORIGINAL: mjr46
I recently pulled my oil gauge out from the pod inside the car and have mounted on the cowl all my gauges that carry liquids
ORIGINAL: ctgreddy
Look AWESOME BTW!!
Design1795
01-24-2017 10:38 PM
