can rear end weight/pad be removed?
Old 04-08-2008, 02:36 AM
crazyhorse
crazyhorse's Avatar
Default can rear end weight/pad be removed?
after an aluminum drive shaft and/or gear change has been installed , can the weight plate on the rear end near the front seal be removed with out causing any problems ? this is on a 93 gt 5spd. thanks.
crazyhorse is offline
Old 04-08-2008, 08:34 AM
WhiteWindsor
WhiteWindsor's Avatar
Default RE: can rear end weight/pad be removed?
I've always removed mine after a gear change since i heard they were there for the original gears and if you replace them the weight is not needed. Anyway i alway's remove them with no problem.
WhiteWindsor is offline
Tyoung68
08-25-2015 04:31 AM
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
Quick Reply: can rear end weight/pad be removed?
