Whats A Good Range
Old 04-08-2008, 12:41 PM
Gronk72
Gronk72's Avatar
Default Whats A Good Range
Running an 88 notch with a lightly modded 5.0.With the engine at operating temp(195) and Mobile1 full synth 10w30 in the pan I am getting 18-20psi oil pressure at idle and between 35-40psi at 2000rpm(both readings from a good quality mechanical gauge). Any Opinions(good or bad).
The Gronk
Gronk72 is offline
Old 04-08-2008, 03:04 PM
Gronk72
Gronk72's Avatar
Default RE: Whats A Good Range
Forgot, Only about 72000 on the motor and its been well maintained(owned her since she was new).
Gronk72 is offline
Old 04-08-2008, 04:24 PM
Gronk72
Gronk72's Avatar
Any opinions/help would be greatly appreciated. Mostlly I am unfamiliar with synthetic oil and wondering if anybody has had any similar reactions with it. My oil pressure was probably about 10-15 psi higher at 2000rpm prior to the synthetic, and about 5psi higher at idle. would using a heavier weight oil be usefull or should I just chalk this up to better flow on behalf of the synthetic and not worry about it.
Gronk72 is offline
Old 04-08-2008, 04:57 PM
FLcracker9
FLcracker9's Avatar
Nothing wrong with the readings you have. Perfectly normal.
FLcracker9 is offline
Old 04-08-2008, 06:16 PM
Gronk72
Gronk72's Avatar
Thanx FLcracker, I know thatbetterpressure doesnt always equalflow and the the same can be said of better flow not equalling more pressure. Just looking for some confirmation that these readings didn't cross some sort of line.
Gronk72 is offline
Old 04-08-2008, 08:40 PM
93_five_oh
93_five_oh's Avatar
and pressure does not equal lubrication...
the rule of thumb is 10 psi per 1000 rpm... so you might even want to try a thinner oil.
5W-20 or so. The thicker the oil the more wear you're getting on your engine.
93_five_oh is offline
Old 04-08-2008, 10:02 PM
Gronk72
Gronk72's Avatar
From what I know on the subject(which is granted limited)isn't 5-20 way to thin for the engine even with the brand new factory bearing clearances set and without 72000m of wear on the engine. Oil thatthin would drop the oil pressure right into the ground and burn out the bearings, would it not.
Gronk72 is offline
Old 04-08-2008, 11:18 PM
lxman1
lxman1's Avatar
10w40 @2500rpm 163,000 miles
lxman1 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
ctgreddy
09-20-2015 08:35 PM
sjforcup19
09-15-2015 09:58 AM
96stang3.8
09-10-2015 06:42 AM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: Whats A Good Range
