Heads/Cam Opinion????????????????
Old 04-12-2008, 11:00 AM
Joel5.0
Joel5.0's Avatar
Default RE: Heads/Cam Opinion????????????????
Based on your user name, I assume the high ports and the Stage 3 cam are installed in a 306 ..... correct? .... if so, the cam and the intake are a mismatch. Like I said, lift numbers do not determine the rpms range.... if that was the case I should be able to turn my junk to 7500 rpms.
If cost effectiveness is key + best performance, you need to set that combo with the correct valve events and optimize those heads "breath-ability"........ just a thought.
Joel5.0 is offline
Old 04-13-2008, 09:32 AM
cobrakiller306
cobrakiller306's Avatar
alright, well can i have your opinion on which intake you would choose?/ yeas it's a 306
cobrakiller306 is offline
Old 04-14-2008, 10:25 AM
cobrakiller306
bump*
Old 04-14-2008, 01:13 PM
5spd GT
5spd GT's Avatar
BBK SSI - 1,500 - 6,500
Track Heat - 1,500 - 6,500
...for a 302.
5spd GT is offline
Old 04-14-2008, 09:36 PM
cobrakiller306
correction*** I meant earlier that i was looking at the r series intake, not the track heat....sorry.
Dokilar
15
10-16-2015 08:13 PM
jstrothe
09-24-2015 12:17 PM
Brett Ludlow
09-23-2015 06:59 AM
stark777
09-21-2015 12:46 PM
Mr. D
09-17-2015 08:17 AM
Quick Reply: Heads/Cam Opinion????????????????
