re:5.0 dont start
Old 04-11-2008, 09:37 PM
stang110580
stang110580's Avatar
Default re:5.0 dont start
hi guys i have a 1990 302 mustang and one day i was driving it and it stall on me i turn it back on i got home and stall again and i try turn in it back on it wont start i change the fuel pump that didnt work any ideas, thanks.
stang110580 is offline
Old 04-11-2008, 09:46 PM
1989convertible
1989convertible's Avatar
Default RE: re:5.0 dont start
do you hear the fuel pump kick on with the key on? did you replace the fuel filter?
1989convertible is offline
Old 04-11-2008, 09:50 PM
SmittysCustomAuto
SmittysCustomAuto's Avatar
Is it trying to start. Is the battery good? Starter good? I'd look at the fuel filter. Could be clogged not allowing fuel to pass.
SmittysCustomAuto is offline
Old 04-11-2008, 09:57 PM
Bullitt91
Bullitt91's Avatar
i say if the pump is running then look at the fuel filter
Bullitt91 is offline
Old 04-12-2008, 05:24 AM
stang110580
i heard the fuel pump kick in and ill try to buy the fuel filter i friend told to change the solenoid switch on the firewall im going to change that and ill change the fuel filter if that dont work ill let you guys know thanks for the replies ill back if it thosent work for more ideas.
Old 04-12-2008, 10:35 AM
nitrous_bob
nitrous_bob's Avatar
the selonoid is fine if it turns over...if it is not firing at all...probably the dizzy module. or possibly the inertia switch, you can bypass that for a minute just to test it.
nitrous_bob is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: re:5.0 dont start
