help plz any sugestions
Old 04-12-2008, 12:18 PM
92mustang510
92mustang510's Avatar
Default help plz any sugestions
Ok so my car runs good for like 10 min at idle then i turn it of then try to start it again and nothing then I pull the fuel pump relay and then it starts and then right away i plug it right back it right after it starts. does any one think it is because of my 24lb injectors and i only have stock mass air flow sensor
92mustang510 is offline
Old 04-12-2008, 10:40 PM
brentloftis
brentloftis's Avatar
Default RE: help plz any sugestions
So if I understand this correctly, when cold or after sitting a while the car starts up normal and runs normal. After shutting off, on restart it cranks but does not start, you then kill the fuel pump via the relay, and crank it and she starts..... Sounds like fuel to air ratio issue, can you get a fuel pressure gauge and checkthe pressure? Could be faulty FPR.
brentloftis is offline
Old 04-13-2008, 12:17 AM
nitrous_bob
nitrous_bob's Avatar
ORIGINAL: 92mustang510
not a chance
and i don't think your pulling the relay, since the car wouldn't start if you did that. it won't fire w/ less than about 20 psi in there , and it doesn't take long for it to tail off after sitting
nitrous_bob is offline
Old 04-13-2008, 01:16 AM
92mustang510
i am pulling the relay under my seat and then i start it and right as soon as it starts i plug it in like right away with n a sec or so then it stays on
supertrooper4
SVT Forums
09-18-2004 03:24 PM
red_line_dxb
07-05-2004 01:35 AM
mustang_2004_65
10-21-2003 11:18 PM
Quick Reply: help plz any sugestions
