Replacing alternator?
Old 04-14-2008, 06:37 PM
90notchLF
90notchLF's Avatar
Default RE: Replacing alternator?
Just got it tested and it was good some where between 14.0 14.5 volts.
My battery was only two month old and I had to get it recharged. What could it be that was discharging it?
Thats wierd if it's not the alternator then wha else?
90notchLF is offline
Old 04-16-2008, 07:54 PM
lxman1
lxman1's Avatar
I don't know, but if you keep unhooking the battery while it is running, you are taking a big chance of frying the computer and other electronics in the car.
The battery acts as a voltage capacitor to eliminate any voltage spikes. If you unhook the battery, and the regulator is stuck open, the voltage can spike up really high which will fry the computer, stereo and any other electrical part that is on. I have even see bulbs blow up when this is done!!
lxman1 is offline
Old 04-16-2008, 08:18 PM
C_A
C_A's Avatar
Has anyone tried the 130A alternator by PA Performance? If so, is it worth the money compared to buying a re-built?
C_A is offline
Old 04-16-2008, 08:37 PM
brentloftis
brentloftis's Avatar
Did you drive it to the parts store and test it while it was installed or take it separated? If it was in the car they should be able to tell you if the battery is getting the charge or not,if it is not and the alt has been verified check the wiring between it and batt.
brentloftis is offline
Old 04-16-2008, 09:24 PM
NYMustang50
NYMustang50's Avatar
Its the battery if you just got it two months ago get a new one they have warrantys on them just say theres something wrong with it it keeps discharging or something..
NYMustang50 is offline
Old 05-15-2008, 12:15 PM
T M T T
T M T T's Avatar
Yeah a month late but C_A take a look
https://mustangforums.com/fb.asp?m=4922407
Or just look @ post 6
90notchLF,how did you make out are ya all set?
T M T T is offline
5.0muscle
01-11-2016 01:17 PM
Golfsito
10-06-2015 11:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Replacing alternator?
