94-95 Intake Manifolds
Old 10-16-2003, 12:23 AM
jhogan2424
jhogan2424's Avatar
Default 94-95 Intake Manifolds
Has anybody swapped intakes on a 94 or 95 stang? I know they are a little different than the 87-93 cars. I was told they needed adapters and other things. I am scared to buy an intake for my car because it may not fit. Does anyone have any info?
jhogan2424 is offline
Old 10-16-2003, 02:03 AM
Sean
Sean's Avatar
TB adapter is the one that I am aware of (could be wrong) I just put a TF track heat with 1" spacer, very easy and straight foward, should be the same for 94 95.
Sean is offline
Old 10-16-2003, 11:23 AM
VicsGT
VicsGT's Avatar
What kind of increase did you see sean?</P>
VicsGT is offline
Old 10-16-2003, 11:37 AM
vfast
I ♥ Acer
vfast's Avatar
he might get 10 hp from a stock engine...but there again it's about putting the right piece together..you will need a bigger t/b and mass to make it worth the $$$$
vfast is offline
Old 10-16-2003, 10:43 PM
Sean
Sean's Avatar
Originally Posted by VicsGT
What kind of increase did you see sean?</p>
I have not been to a dyno yet, but I can most deff. tell a big diff.
But as vfast posted I have other mods to go along with it, without those other mods It would not have been the same.
Before the intake I would consider TB, MAF, bigger injectors, exhhaust and so on.
Sean is offline
mrtrodonet
09-19-2020 03:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
daltron
04-28-2016 08:10 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: 94-95 Intake Manifolds
