Gears grinding and not moving
Old 04-22-2008, 05:28 PM
TRexGAWD
TRexGAWD's Avatar
Default RE: Gears grinding and not moving
If there's slack in the cable then it's time for a replacement. You might get away with adjusting it though.
Oh and Keek89gt, what do you mean you don't use a clutch when shifting. That's your problem right there then, rpm matching puts uneccessary wear on your gears and if you're grinding then try using the clucth that's provided in your car for a reason.
TRexGAWD is offline
Old 04-22-2008, 05:40 PM
302f150
302f150's Avatar
lol, yeah, yo ucan shift w/o a clutch, but come on man, push the clutch in next time you drive and see if the problem goes away
302f150 is offline
Old 04-22-2008, 06:28 PM
FoxGT
FoxGT's Avatar
ORIGINAL: keek89gt
ohh and btw, it will always grind in reverse, cuz theres no syncros in reverse
every mustang I know does that & every mustang i know doesnt' do it if you push the clutch in, push it into 1st, then into reverse.
FoxGT is offline
Old 04-23-2008, 04:43 AM
Jfsram
Jfsram's Avatar
ORIGINAL: FoxGT
ORIGINAL: keek89gt
You boys have not tried this in a 93 yet have you?
Jfsram is offline
Old 04-25-2008, 07:00 PM
FoxGT
FoxGT's Avatar
ORIGINAL: Jfsram
ORIGINAL: FoxGT
ORIGINAL: keek89gt
No [&o]
FoxGT is offline
Old 04-25-2008, 09:44 PM
bbbngowc
bbbngowc's Avatar
I adjusted the clutch and now it's only grinding in 3rd. I'll prolly adjust it some more and see if it goes away. Also the clutch pedal is way softer now too.
bbbngowc is offline
flash_xx
10-16-2015 07:23 AM
Bokeo
10-10-2015 08:28 PM
UrS4
10-03-2015 06:23 AM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: Gears grinding and not moving
