exhaust question
exhaust question
I own a 92 LX (stock at this point) and am installing a flowmaster cat back exhaust. Both side flanges that connect to the catalytic converter piped needed to be drilled bigger to fit. The passenger side system finally went on after tweaking multiple times. The drivers side flange would not fit either and also needed to be drilled. When installing the muffler, to fit snuggly on the cat pipe, it was angled way off to the side. I can get it to sit where the muffler belongs by putting it in the stock rubber hangar. I am having a hard time connecting the tail pipe to the muffler. Flowmaster said to loosen all of the bolts including the H pipe to exhaust manifold. Any other suggestions would be appreciated. Getting quite frustrated.
Michael
Michael
RE: exhaust question
yeah get new headers, h-pipe and stop being a baby exhaust is probably the easiest thing to put together. haha jk about the baby part. anyway loosen most of the stuff up and start fitting it all together then start tightening up bolts and it will all come together. as it starts getting tighter together start adjusting it before it gets too tight
ORIGINAL: HACKGT350
i wish i knew how to weld
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
