more clutch woes
more clutch woes
well its doing it again, the clutch pedal is returning slow and its slipping under heavy acceleration. it did it last year and i let it set all winter expecting to do the clutch this year BUT it stoped and the car acted normal for 4-5 months under some verry heavy abbuse. it did fine this morning but when i put a new cap and rotor in the car it started slipping again[:@]any suspects? im guessing slave cylinder
RE: more clutch woes
well its obviously not disengaging all the way so something is obviously hanging up somewhere. i would start by checking your quadrant and cable. if worst comes to worst buy the billet quadrant set and a new clutch. the diaphram on the pressure plate could be completely worn out and thats why its slipping but with the way you say the pedal is coming back slowly it sounds like its still engaged a little bit and thats why its slipping. if you keep driving like this you WILL need a new clutch
well the transmission on these mustangs are a new bird to me. im going to order a spec stage 3+ clutch, whats a good quadrant and cable and wheres a good place to get them on a sunday night?
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
