AOD fluid change
Old 05-06-2008, 12:34 PM
Foxbodyforever
Foxbodyforever's Avatar
Default AOD fluid change
So i just got under my car to start taking the pan bolts off the trannsmission but i realized that the 2 foward bolts are almost underneath the crossmember, is there any trick to getting these off? and if i can't get them off what should i do, could i consider reusing the gasket so i don't have to take the pan off?
Foxbodyforever is offline
Old 05-06-2008, 01:33 PM
Foxbodyforever
Default RE: AOD fluid change
bump
Old 05-06-2008, 02:03 PM
brentloftis
brentloftis's Avatar
Are you talking about the trans support cross member? If so could you use a jack or stand to support the trans and remove the cross member to get to the bolts? Anyway you could get a picture?
brentloftis is offline
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
Quick Reply: AOD fluid change
