Please Help Guys.
Old 05-06-2008, 06:28 PM
81bird
81bird's Avatar
Default Please Help Guys.
So ive started puttin my 302 back together. I got it as a 88 h.o. 302. So i tore it down to the bottom end. I put on sum gt-40p heads, edlebrock 4 barrel intake, holley 650cfm, and sum bbk shortys. I had a 255 that i pulled outta the car this motor is goin in and put the timing cover off the 255 on the 302. I went to put on the mechanical fuel pump and it dont fit in right. Do i need to run a electric fuel pump? Also theres a post type thing that comes off the side of the front of the block what is it for? It has a hole in it...Another is can i run the disty off the 255? Or do i gotta get a special disty? THe car its goin in is a 81 tbird that was carb thats why im switchin this motor to carb...
81bird is offline
Old 05-06-2008, 07:06 PM
FLcracker9
FLcracker9's Avatar
Default RE: Please Help Guys.
Buddy, you got me baffled?, What's a 255???. Does your motor even have a fuel pump eccentric on the cam (this operates the manual pump).
FLcracker9 is offline
Old 05-06-2008, 07:15 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Get a timing cover for a 302. Whatever a 255 is it won't work. But like cracker said there is the fuel pump eccentric bolted to the front of the timing chain assembly. It will be a little difficult getting the bolts started but after you get them started it will seat itself as you bolt it the rest of the way down. Also get a DIZZY from a 302. If you buy a stock one get one for the year of the car it is going in that way the wiring will be right. If your motor doesn't have the eccentric you may want to get one even if you don't use the mechanical pump bc it helps in the harmonics of your cam and timing assembly from what I have read.
projectresto83 is offline
Old 05-06-2008, 08:41 PM
silver91gt
silver91gt's Avatar
ORIGINAL: FLcracker9
the fuel pump eccentric bolts on the front of the timing chain
silver91gt is offline
Old 05-06-2008, 08:53 PM
silver91gt
silver91gt's Avatar
ORIGINAL: 81bird
The 255lph fuel pump will work with a special regulator, but it may be easier to just get a pump made for a carb application.
If the "post thing" is right beside the oil filter then it is for the oil pressure sending unit.
the distributor will work as the 255/260 uses the 302 block.
Old 05-06-2008, 09:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: 81bird
just run a elec pump..it 'll supply fuel so much better and a "disty off the 255"[sm=wtf.gif]
mjr46 is offline
Old 05-06-2008, 10:25 PM
81bird
81bird's Avatar
A 255 is the same block as a 302..its just alot smaller bore and all...The disty when i bought it for the 255 was actaully for a 302 so i imagine that works...fuel pump eccentric bolts? Anyone got a pic maybe that will help...
81bird is offline
Old 05-06-2008, 10:43 PM
PJC Racing
PJC Racing's Avatar
88 5.0 H.O. has a roller cam, unless you changed the cam to a flat tappet cam, you CAN NOT use that distributor unless you you change the gear to a steel gear. It will go in with the cast gear but it will be like it's in a grinder when you run it.
PJC Racing is offline
Old 05-07-2008, 07:33 PM
FLcracker9
FLcracker9's Avatar
ORIGINAL: 81bird
No pics, but it's a cup shaped piece that bolts throughthe timing chain gear and onto the camshaft. It sits off center of the camshaft/timing chain gear, and makes contact with thefuel pump arm as the motor spins.Some fuel injected motors came with them even though they weren't needed. My 86 F150 had one even though it was EFI.
Old 05-20-2008, 11:11 PM
81bird
81bird's Avatar
Alright everyone got the motor in..just gettin the disty now..thought the stocker would work if i switched the gear on it but the drive on it is shorter then the roller cam disty that came on the motor..
81bird is offline
JDWalton
09-24-2015 08:47 PM
GimpyHSHS
09-18-2015 12:27 PM
v8sn95
09-07-2015 10:17 AM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Please Help Guys.
