Where is the Starter Relay???
Old 05-15-2008, 08:13 PM
  #21
OneFastEclipse
OneFastEclipse's Avatar
Default RE: Where is the Starter Relay???
Anyone alive out there?
OneFastEclipse is offline
Old 05-15-2008, 08:38 PM
  #22
Joel5.0
Joel5.0's Avatar
Check the last diagram here ..... if you remember the relay socket diagram, there is one thing that will cause the starter relay to stay activated....... and that is the constant presence of the 12-vdc START voltage at the corresponding coil terminal (85 or 86 prong). Since you disconnected ignition switch connector at the steering post (right?)...... the other alternative is that theres a short of the START wire to the relay, somewhere in the wiring harness, to a 12-vdc source. Some wire tracing is required. LUK
Joel5.0 is offline
Old 05-15-2008, 08:45 PM
  #23
OneFastEclipse
That is right, I disconnected it at the steering post. I suppose I'll try my luck tracing the wires, thanks for the help.
Seanam
10-04-2015 10:15 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
logan409
09-26-2015 07:43 PM
jc409
Convertible Tech
09-24-2015 03:38 PM
schecterplayer
09-23-2015 08:38 AM
Quick Reply: Where is the Starter Relay???
