maf sensor question
maf sensor question
i have a c&l mass air housing(73mm) what sensor should i look to get to run in it with the 24pound tube....currently im running a 94-95 cobra maf sensor and housing in the car....my cars set-up is in my sig...thanks
RE: maf sensor question
It depends on what ecu you have...
A9L/A9P - use the F1ZF sensor (this is the stock sensor for 88-93 Mustang 5.0HO motors, except 93 Cobra)
Does your 'Cobra MAF' have a F1SF in the part number?
The F2VF sensor is not from the 93 Cobra meter... The 93 Cobra used an F1SF sensor.
Only the 94-95 Cobras used the F2VF (along with all other Mustang models those years)
Was this an ebay purchase? Those guys are lying scamming pieces of ****!
That meter is NOT calibrated for 24's when used with an A9L. (<--- those comments are greatly simplifying things, but make the point)
The sensor you need for ANY C&L meter being used with ANY Fox ecu (again, except for the 93 Cobra), will be marked F1ZF.
You will find them at the j/y on a variety of vehicles.
If buying at the parts store, ask for a sensor for a 1990 5.0HO... manual/auto & ac/non-ac won't make any difference.
good luck.
good luck.
TfcCDR
09-14-2015 12:08 PM
