guestimated numbers
guestimated numbers
edelbroke rpm2 lower/upper
AFR 205cc 61cc
347 liberator dish piston
Xfi stroker cam Duration @.050 236/248, Lift .579
good build?
whats your guesstimate on the numbers?
much appreciated
AFR 205cc 61cc
good build?
much appreciated
RE: guestimated numbers
First off the combo is mismatched a little bit, but thats OK my original combo was mismatched heavily and everyone though it would make little power and have no torque, but that was'nt true. You should swap out the RPM2 for a victor 5.0 or some kind of top end power intake. The duration on the cam is a little low too. Them heads make their power at 3500-8000rpms. The duration on that cam is probably only good for 7000rpm if that. If you are going for an all out RPM motor then your combo is a little off but it will still make good horsepower down low.
I would say a good 400rwhp mabey a little more. But if youswap out the RPM2 for a higher RPM intake like avictor 5.0 or trickflow box with a nasty solid roller cam and rev it to 8000rpm it would be in the 500+ range. I'm not really good at guessing hp numbers but thats a good estimate.
I only have a 302 but its a strong running 302. Last timeI had it tunedI made more power than the guy before me with a 331 and bigger heads, so it all depends on how the motor was built and how high you want to rev it.
ORIGINAL: redemption
AFR 205cc 61cc
good build?
much appreciated
AFR 205cc 61cc
good build?
much appreciated
09-23-2015 01:28 PM
