Changing a fuel filter
Old 05-21-2008, 09:25 PM
Foxbodyforever
Foxbodyforever's Avatar
Default Changing a fuel filter
Is it necessary to depressurize the fuel system before changing the fuel filter?? I heard you have to start the car and then pull the fuel pump relay while the engine's running so that all the lines depressurize and you won't rupture any lines when's you take the old filter off
Foxbodyforever is offline
Old 05-21-2008, 09:54 PM
88fox50
88fox50's Avatar
Default RE: Changing a fuel filter
never heard of that man, just get up under there and pop off the clips , slide the hoses off , slide em on the new filter and replace the clips... all done. ....then when you go to start the car ...just turn the key forward to let the fuel pump pressurize..(do it a couple times if you want) .. then start it.
all your doing by pulling the relay is turning off the pump and running the fuel out thats in the lines so it dont leak out as much as you swap the filter.not necesary to go thru all that IMO...
88fox50 is offline
Old 05-21-2008, 09:55 PM
stang8689
stang8689's Avatar
You can but I just do it quick, not much comes out
stang8689 is offline
Old 05-21-2008, 09:57 PM
Foxbodyforever
ok and how bout disconnecting the negative battery terminal? should i do that?
Old 05-21-2008, 10:03 PM
shaun8850
shaun8850's Avatar
well with any instructions they say to disconnect the neg, use your best judgment. pop your gas cap will releave any pressure in tank. get a rag and pop the clips little fluel should leak change the filter, turn key listen for pump, check for leaks and start.
shaun8850 is offline
Old 05-21-2008, 10:12 PM
getafewlives
getafewlives's Avatar
Dont worry about instructions. You wont get much gas on you. Dont worry about the battery or anything. Just do as 88fox5.0 said. Its easy as pie.
getafewlives is offline
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
whatsup62
10-16-2015 03:07 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Changing a fuel filter
