91 GT Speedometer
Old 06-05-2008, 07:57 PM
SJPajak
SJPajak's Avatar
Default 91 GT Speedometer
Cananyone let me know how hard or easy it is to change the speedometer in a 91 GT, and if possible give a brief step-by-step.
Thanks,
Stan
SJPajak is offline
Old 06-06-2008, 09:06 AM
bdptcob
bdptcob's Avatar
Default RE: 91 GT Speedometer
The speedometer? It's a gauge cluster so you have to replace the entire cluster as far as I know. If you undo the cluster cowl and pull the cluster, you'll see it's all circuitry back there. There isn't an area for just the speedometer.
bdptcob is offline
Old 06-08-2008, 08:40 PM
SJPajak
SJPajak's Avatar
yea well i just worked on it this weekend and i took out the cluster and the speedo just slips out from the front no problem. so i didnt have to replace the whole cluster thank god.took about an hour to do.
SJPajak is offline
Old 06-08-2008, 09:38 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: SJPajak
that's correct. once clear plastic cover is removed speedo comes right out.. glad it worked for you
mjr46 is offline
Old 06-08-2008, 10:44 PM
SJPajak
SJPajak's Avatar
it doesnt read correctly though, gear 3.55s and i have a taller tire
how do i fix that?
SJPajak is offline
Old 06-08-2008, 10:46 PM
mjr46
mjr46's Avatar
you need to pull out the speed drive assembley down on the tranny attached to speedo cable and replace the little gear on the end with the correct one
mjr46 is offline
Old 06-08-2008, 10:56 PM
SJPajak
SJPajak's Avatar
are those the color coded ones.? because i think i have seen threads on this before on another forum searching on this topic.
SJPajak is offline
Old 06-08-2008, 11:16 PM
stang8689
stang8689's Avatar
Yes they are color coded
stang8689 is offline
Old 06-09-2008, 10:02 PM
SJPajak
SJPajak's Avatar
alright got it thanks a lot.
SJPajak is offline
articman
06-21-2018 11:45 PM
Mr. D
Wheels & Tires
15
08-22-2015 02:58 PM
Nurdyguy
08-21-2015 10:23 PM
danclint
11-28-2004 10:32 PM
Leadfoot
09-10-2004 03:05 PM
Quick Reply: 91 GT Speedometer
