'94 GT (sn95) power window fix???
RE: '94 GT (sn95) power window fix???
stick your arm into the door and toward the window motor, after the bolts are out its not gunna fall immeadiately, so just wiggle it till it does. make sure you disconnect the wires comming from it in a place where you can reattach them without too much difficulty
The only bolts I can see are the 3 bolts that hold the cover on the window motor. They don't appear to be mounting bolts and as such they aren't securing the motor to the door, but I think the rivets are. I'd appreciate less ambiguous replies.
ORIGINAL: mojopony
ORIGINAL: mojopony
stop assuming things and try the suggestions.
zanemoseley
09-06-2015 12:58 PM
94, convertible, fix, gt, installation, motor, mustang, power, remove, replacement, romove, sn95, window
