86 gt tranny how come question
Old 06-13-2008, 09:08 PM
PUDman
PUDman's Avatar
Default 86 gt tranny how come question
does anyone know why automatic tranny fluid is used in a manual 5 speed 1986 gt? i'm the original owner and the tranny is stock and works fine, but i just want to know why this is.
PUDman is offline
Old 06-13-2008, 09:14 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: 86 gt tranny how come question
there are many small passages and tight tolerances within a t-5 where viscosity is the primary concern for lubrication..gear oil and it's thickness would not be able to penetrate such areas fast enough to provide the proper and adequate lubrication
mjr46 is offline
Old 06-13-2008, 09:39 PM
HACKGT350
HACKGT350's Avatar
borge warner actually recomends gm syncromesh for the t5 but ford went with atf because its ford
HACKGT350 is offline
Old 06-13-2008, 10:42 PM
stang8689
stang8689's Avatar
I use syncromesh
stang8689 is offline
Old 06-14-2008, 12:14 AM
redpony88
redpony88's Avatar
like mjr said, they have tight passages and regular gear lube wouldnt work. i use rp syncromaxx, it's made for manual trannys that use atf
redpony88 is offline
Old 06-14-2008, 12:57 AM
PUDman
PUDman's Avatar
thank you all for the info. i never would have guessed. it must work because my stang and stock tranny have 357,800 original miles
PUDman is offline
Old 06-14-2008, 05:32 AM
HACKGT350
HACKGT350's Avatar
wow and i thought i had a lot of miles
chrisdbassplayer
10-13-2015 06:53 PM
UrS4
09-30-2015 10:13 AM
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: 86 gt tranny how come question
