Wheel bearing
Old 06-14-2008, 06:50 AM
hemi_04d
hemi_04d's Avatar
Default Wheel bearing
So recently any time I drive in the rain or through a puddle, the pass. side rear starts making a clunking sound, especially when I go to slow down. I was thinking wheel bearings. I pulled the drums off and it appears to be a one piece deal where the axle has to come out. I have never pulled axles before, is it a hard job? Does this sound like it could be the problem?
hemi_04d is offline
Old 06-14-2008, 10:02 AM
red95gtconvert
red95gtconvert's Avatar
Default RE: Wheel bearing
I would consider it a semi tough job and I have done it under 2 hours before.You will have to pull the wheels, brakes, differential cover, unbolt the carrier cross pin retaining bolt and slide the cross pin out, remove the c-clip for the axle you will removing then slide the axle out. Carefully pry the axle seal out then using a bearing puller with a slide hammer pull the old axle bearing out, it will be a little tough but once it starts moving it is not to bad. Intsall the bearing and seal using the bearing/seal driver, you can rentit from Autozone. Reassembly is opposite of tear down. Good luck, it'sa very doable job just take your time and do it right the first time, seals andaxle bearings are sensitive
red95gtconvert is offline
Old 06-14-2008, 10:31 AM
bighungrymatt
bighungrymatt's Avatar
^ good explanation
once you know what you are doing its not hard at all, it might take some time, but its not bad
bighungrymatt is offline
Old 06-14-2008, 08:39 PM
hemi_04d
hemi_04d's Avatar
Took me about an hour, not bad considering I have never done it before. I will finish it up tommorow and see what happens next time it rains. I think it was useless though because the seal looked good so I don't think that was my problem...
Sooo, what part in the rear would "clunk" when it got wet? Thats the only time I hear it is when I drive in the rain or go through a mud puddle...
hemi_04d is offline
Old 06-14-2008, 10:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
takes less than 15 min to pull and axle.....remove wheel, drum, leave brakes on....and remove rear cover and 5/16 bolt holding pin in...pull pin, push axle in a little grab c-clip with magnet and pull axle out..to remove bearing, you'll need a puller/ slap hammer
mjr46 is offline
Old 06-14-2008, 10:34 PM
red95gtconvert
That's because you are the greatest mustang mechanic of all time
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Wheel bearing
