Motor mount DIY
RE: Motor mount DIY
This is how I did it
1. I put it up on 4 jack stands
2.Remove the 1big nut that bolts mount to K member oneach side
3. Raise engine w/ jack(place block of wood on jack)
4. Remove the2 bolts on each side that bolt mount to engine block
Installation reverse of removal
Also, I had to remove my CAI intake and I loosened the 4-5 bolts that hold fan blade, so i could slip it out of shroud to raise engine higher.
RE: Motor mount DIY
If the trans is out then you might not be able to just jack up your motor.......... You may be able to get one side at a time but usually the rest of the drive line is in place to keep the motor from falling back.
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
