Dammit, not again
Old 06-23-2008, 11:18 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Dammit, not again
ORIGINAL: 67mustang302
That may be it as well. It seems that back in the day guys could run their engines without oil at all to try and kill them and they would hold up just on the film that was present. But modern oils are sucking severely these days. It may just be the oil. I lost the thrust running Castrol, which apperantly is some of the worst these days, and this rod bearing just went using Valvoline VR1. I've run Mobil 1 in the past and never had a problem with it, it actually ran in the engine that had the half siezed wrist pin and seemed to keep it from totally galling.
I'm gonna be switching to an amsoil topline grade oil soon right now I'm running castrol regular oil for breakin with BG MOA additive for extra protection..and in my 66 since it's flat tappet cam equipped, quaker state with BG MOA ALSO AND 3 YEARS ON BUILD WITH NO PROBS YET........Guess its time to sell it before it develops a prob[:@].. I've jinxed myself now!!![:'(]
mjr46 is offline
Old 06-23-2008, 11:27 PM
67mustang302
67mustang302's Avatar
I was running the Castrol HD straight 30 before the thrust failed. as soon as I switched to the 5-30 syntec, the thrust crapped out within about 800 miles.
67mustang302 is offline
Old 06-23-2008, 11:30 PM
mjr46
mjr46's Avatar
man that sucks!!!!!!!!! time to build it bigger and faster now!!!
mjr46 is offline
Old 06-23-2008, 11:36 PM
67mustang302
I wanted to go 347 last year when I first rebuilt it, but the previous builder had shoved that #1 piston in and it scored the lower portion of the cylinder. It was already .040 over, and going to a 347 would have likely put the top compression ring in a position where it would be passing over the grooves in the cylinder wall. With a 302 it was fine. I was trying to keep cost down by going to another block, but in the end this has proven to be just as costly, if not more so.
justingt
01-16-2006 02:43 AM
5_liters
12-17-2004 12:32 PM
Quick Reply: Dammit, not again
