no compression
Old 06-29-2008, 09:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: no compression
so what was the problem?? or none exists now??
mjr46 is offline
Old 06-30-2008, 05:19 AM
tinner7
tinner7's Avatar
Valve was stuck open, so no compression, I ran a new complete compression test on the motor, and all cylinders are within 5-7psi of each other. I am going to finish putting it back together later this week, and see what happens. Since my car is carbed, shouldn't take too long to get it running again and see if my efforts where justified.
tinner7 is offline
Old 06-30-2008, 06:55 AM
AdderMk2
Banned
AdderMk2's Avatar
it would be wise of you to remove the head and bring it to a machine shop. When valves get stuck, its time to replace parts.
sounds to me like you have bad springs, worn guides, and/or bent valves
please don't run your car like this
AdderMk2 is offline
Old 06-30-2008, 05:47 PM
FoxGT
FoxGT's Avatar
Probably a good idea to find out why the valve was sticking in the first place.
FoxGT is offline
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
bconboy
09-21-2015 12:52 PM
uberstang1
09-20-2015 06:42 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Quick Reply: no compression
