clunk noise while driving
Old 07-02-2008, 11:58 AM
brentloftis
brentloftis's Avatar
Default RE: clunk noise while driving
My guess isrear wheel bearings
brentloftis is offline
Old 07-02-2008, 02:19 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
ORIGINAL: brentloftis
brand new, lubed and installed properly
FivePointOhh is offline
Old 07-02-2008, 03:03 PM
fourfivefour
fourfivefour's Avatar
Check your front wheel bearings.
Check your ring and pinion and bearings and your spider gears. Axle splines wear too, but would give you a clunk when getting on and off the gas.
fourfivefour is offline
Old 07-02-2008, 10:06 PM
95greengt
95greengt's Avatar
have you checked you ujoints thats what mine did
95greengt is offline
Old 04-08-2013, 12:26 PM
ledglow
ledglow's Avatar
Default same problem
Originally Posted by FivePointOhh
i have a clunk noise while driving. only when coasting in or out of gear it goes, clunk clunk clunk clunk and the slower you go the clunk noise slows as well like it only at a certain point in the rotation of the rear wheels.
the wear thing is that the clunk stops when the car is under load, even the slightest amount of throttle stops the clunking.
any ideas of what the problem is? or how to narrow down what it is?
Hey i am having the same problem ! has anybody figured out what exactly it is yet?
ledglow is offline
Old 04-08-2013, 06:03 PM
Maxwelhse
Maxwelhse's Avatar
If this happens consistently every time you decelerate, can you replicate the condition while turning the wheels manually with the car on jack stands?
If you can get it to makes the noise under human power it will be a LOT easier to find.
Maxwelhse is offline
Old 04-08-2013, 06:15 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
necro thread revival!
rmodel65 is offline
Old 04-08-2013, 06:27 PM
Maxwelhse
Maxwelhse's Avatar
doh!
Oh well.. I guess SOMEONE is having the issue still.
Old 04-10-2013, 10:17 AM
ledglow
ledglow's Avatar
Ya I'm still having the problem :/ I'm almost sure its not wheel bearings because I had it on a jack stand and rotated both front wheels....... no noise, only when I'm slowing down I really think its the u joints I'm just going to drop the drive shaft and replace the whole thing iv wanted to replace it with an auminum one for a while this just gives me a excuse to finnaly do it. Haha any sujestions for brand ?
ledglow is offline
Old 04-12-2013, 08:20 PM
CW
CW's Avatar
Since this thread is back i'll post some things I have run into over the years that have caused similar noises.
u-joints worn or incorrect ones installed, bad trans mount causing front of driveshaft to rub the tunnel on the floor, Wheel weights on inner edge of front wheels rubbing front calipers, and most recently just this week on the 84 I picked up all four bolts holding the drive shaft to the rear diff were loose and backing out.
Glad I caught that one when I did.
CW is offline
Quick Reply: clunk noise while driving
