wire harness tool?
wire harness tool?
does anyone know where I can get the tool for disconnecting the wires out of the back of the wire harness connectors? Im talking about taking out the actual metal clips that click into the back of the harness connectors if theres more then one im looking for all of them please send link or at least tell me what the technical name is for it
RE: wire harness tool?
I use a small pocket screwdriver (flat). On some connectors you'll have to take the lock out. The lock is a slim red piece usually. You'll have to pry it out. Then you stick a small pocket screwdriver down into the connector on the opposite side of the wires. You'll have to push a little plastic tab away from the metal prong then pull the wire. If the wire doesn't come out pretty easily then you don't have the plastic prong pulled out right or not enough.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
