No Fuel... Ideas?
Old 07-23-2008, 10:42 PM
NotFingflyinnow
NotFingflyinnow's Avatar
Default No Fuel... Ideas?
Im not getting any fuel to the motor of my '88 GT. I know the fuel pump is good, and the relays are good... I was thinking a bad ground or broke wire.
When I turn the key the relays and pump wont turn on, any ideas?
NotFingflyinnow is offline
Old 07-23-2008, 10:43 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: No Fuel... Ideas?
find the fuel pump relay signal wire at the ECM and test your way back to the pump
AdderMk2 is offline
Old 07-23-2008, 10:48 PM
NotFingflyinnow
Alright, Ill give that a try.
Old 07-23-2008, 10:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the relay should be under the drivers seat I believe.. grab a test light and start testing..you may need a diagram to Id appropriate wires
mjr46 is offline
Old 07-23-2008, 11:08 PM
mustangsneverdie
mustangsneverdie's Avatar
i think you have a fuel pump safety shut off in the trunk push the button and see if that helps
mustangsneverdie is offline
Old 07-26-2008, 06:26 AM
NotFingflyinnow
Update:
Found the lose ground! Car is running now
Thunderball
15
11-22-2015 11:49 PM
Sixer4Life
10-12-2015 04:26 AM
ChampInSD
10-02-2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
marc954
09-29-2015 11:18 AM
Quick Reply: No Fuel... Ideas?
