How high of a lift can stock springs handle?
Old 08-12-2008, 08:18 PM
Joel5.0
Joel5.0's Avatar
.490" intake and .450" exhaust........ this does not take into consideration the other important specs required for aftermarket camshafts ..... spring rate, closed valve and opened valve pressure....... which makes the stock springs "barely" acceptable for a stock camshaft...... regardless of mileage.
Joel5.0 is offline
Old 08-12-2008, 08:31 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
stock springs = stock cam and e cam with stock springs = cam will no reach full potential..been there done that...I had to short shift everytime with such a set up or it's float the valves and literally fall on it's face until I solved problem when I swapped cam for an f-cam and matched springs
mjr46 is offline
10-05-2015 06:07 PM
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
cbird1177711
09-02-2015 08:51 PM
iculookin
09-02-2015 12:34 PM
Quick Reply: How high of a lift can stock springs handle?
