9" swap
Old 09-04-2008, 11:33 PM
silentvoice19
silentvoice19's Avatar
Default 9" swap
So does a ford 9" bolt right up???? what do i need exactly?I got a 9" for fee in great condition with only 30k on it.
silentvoice19 is offline
Old 09-04-2008, 11:38 PM
rudy7586
rudy7586's Avatar
nope sure doesnt
they sell made 2 bolt up2 fox bodies though!!
its gotta bolt up tha same way tha one u hav on ur car does or start customizin lol
rudy7586 is offline
Old 09-04-2008, 11:39 PM
primetime5.0
primetime5.0's Avatar
your just wasting your money putting in a 9in
primetime5.0 is offline
Old 09-04-2008, 11:40 PM
silentvoice19
ok nvm ill sell it and use the money to rebuild my 8.8. I can hear and feel it grindin alittle. Also what type of fluid does a t5 take?
Old 09-04-2008, 11:43 PM
primetime5.0
dexron mercon 3 I believe
Old 09-05-2008, 01:02 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no a nine inch needs the correct bracketry welded on to the case to make it bolt up, try currie enterprises to get an idea of what it'll need to look like
mjr46 is offline
Old 09-05-2008, 01:28 AM
silentvoice19
well im gonna outfit my 8.8 with 31 spline stuff.
Old 09-05-2008, 07:48 AM
5.0kid
5.0kid's Avatar
i've been told that the 9in rear needs more power to turn it since the gears and everything is larger not a huge amount more hp but its like a centri blower i guess its going to take power to get it turning then your fine after its going.
5.0kid is offline
Old 09-05-2008, 08:26 AM
nseoi
nseoi's Avatar
just like most things, you go bigger when you need to hold more power. thats y they put 7.5's in 4 cyl, not cause they are crappier but because its better for the weaker motor.
nseoi is offline
Old 09-05-2008, 06:28 PM
tinman
tinman's Avatar
I was thinking of using a 9" in my '84 last year when I blew up the 8.8...
What I found out........
1) It uses more power to turn.
2) It was going to be about a $2400 bolt-in. This was after I had spool, Moser axles, 4.30 gears set-up and a new, modified housing.........
tinman is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: 9" swap
