*** Backfire In Manifold?? ***
Dude, thanks for all your help, "I really appreciate your advise" The last thing I want is to blow my motor. It took me years to get to this point, so I need to somehow ("If I can")leave everthing in place, "bypass the blower" and drive it the way it is until I can get the injectors & pump................If thats possible!!
Try sending this again:...Thanks guys, The last thing I want to do is blow my motor up! It took me a long time just to get to this point! Like I said, "If possible" I would like to leave the blower in place but "bypass it" and drive it as it is until I can afford the injectors & pump! Again, thanks to all you guy's for your help & advice.......
I don't think you need to "bypass" it, per se. All you need to do is run the lowest possible boost until your fuel system is up to snuff. If you really want to bypass it, just unhook the plumbing and take the belt off - just be sure to plug the inlet and outlet so no debris can get in there.
