1991 5.0 fuel injector does not pulse #1 cyl
Ok,
I have been having this problem with my 91 LX 5.0, it runs real rich, I troubleshot it down to #1, I pull the plug and it is drenched with fuel, checked spark, and compression and all is good, I replaced plugs, wires, cap, and rotor. I thought maybe it was a bad injector, so I replaced #1 injector...NO JOY. Today I decided to check the fuel injector leads and sure enough they all pulse except for #1 which is a constant 14.92 VDC. Does any one have any ideas.
Thank you.
Mark
P.S. I am a new guy here, so if I posted this in the wrong spot, please let me know.
Thank you.
Mark
Is that 14.92 voltage with the engine running? I'm a bit confused because if the injector didn't pulse there would be no fuel in the cylinder. You should have the same battery voltage at the injector as you have at the battery (or real close) the ECA controls the ground and cycles the injector. Check to see if there is a constant ground at that injector. take your test light and go from one pin to the other at the injector connection and see if you have a solid light. Also check to see if you have spark at the plug on the same cyl. I'll check back with you later
Sorry about that, it is with the car running, and the spark plug fires...I checked all leads with the car running, and they all open, and close with the exception of the #1 which is the same voltage as the battery, actually the alternantor because it is in the 14 volt range. I checked the wires (#1) and one of them has continuity to ground.
Thank you.
Mark
Thank you.
Mark
Thank you.
Mark
Thank you.
Mark
Thank you,
I will give it a shot and get back to you. I do have a 87 GT ECU, I wounder if I should just plug it in and see if it works, and if not start chasing wires.
I do appreciate your help.
Have a great day.
Mark
Have a great day.
Mark
Just wanted to update everyone.....my problem was the ECU, plugged my 87 McLaren ECU in and everything is good, although I do have a check engine light, but I figure its looking for some thing that is not there, no big deal, I do need to find a compatible ECU for my 91.
Thank you all for your help.
Mark
Mark
