Help AOD shifting bad...
Old 12-24-2008, 07:43 PM
9165pt0
9165pt0's Avatar
Default Help AOD shifting bad...
Hey my trannys been shiftin wierd. not sure if anything can fix it or not. plz help. its the original tranny, its 20 years old. but the 1-2 shift is super fast and a lil weak, it feels like it didnt really shift. and the 2-3 shift is always a little delayed and really hard. Someone told me the valves might be sticking and i should change the fluid. Any advice? I just wanna make it shift better or daily driving.
9165pt0 is offline
Old 12-24-2008, 09:57 PM
NoGo95GT
NoGo95GT's Avatar
I would flush the transmission fluid and change the transmission filter. If that solves your problem I would invest in a tranny cooler and shift kit.
NoGo95GT is offline
Old 12-25-2008, 11:34 AM
302army187
302army187's Avatar
the AOD has two different shafts for 1-2gear and 3-4-reverse gear.
its a common sign of a dieing AOD when your 2-3 shift get's sloppy.
try a fluid flush, and shift kit, a tranny cooler is a MUST if you plan on keeping it.
my nitrous use has torn my AOD to shreds so soon, i will be ripping it out.
302army187 is offline
Old 12-25-2008, 07:31 PM
9165pt0
9165pt0's Avatar
ok sounds good. hey i have heard that if you do a tranny flush in a older worn out tranny, that it can ruin it more. and make the shifts soft n sloppy. is this true?
9165pt0 is offline
Old 12-26-2008, 05:11 AM
302army187
302army187's Avatar
if your really that worryed about it, i would just baby the car, and swap in a built AOD, witch cheapest ive found is around $2,000, more like $3,500 if you want something nice.
or you can swap in a 5speed. a T5 will cost around $1200-2000 depending. or im putting in a TKO600, total cost will be around $3500.
all depend's on what you wanna do.
Old 12-26-2008, 09:25 PM
9165pt0
9165pt0's Avatar
yah ur right. ill check around and see what i can do for a swap. thanks
9165pt0 is offline
Old 12-26-2008, 09:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check the TV CABLE adjustment!!
mjr46 is offline
Old 12-27-2008, 12:45 AM
9165pt0
9165pt0's Avatar
ok i will check that. where is it located?
9165pt0 is offline
Old 12-27-2008, 03:11 AM
302army187
302army187's Avatar
http://www.youtube.com/watch?v=6L3hNzxdiYw
that video is what i did, seemed to help alot!
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Help AOD shifting bad...
