Prostar skinnies and 13" cobra brakes sn95 spindles
Old 01-13-2009, 11:13 AM
ruger311
ruger311's Avatar
Default Prostar skinnies and 13" cobra brakes sn95 spindles
for my 89 GT Vert, with UPR k member swap, ive got as set of 15x3.5" pro star skinnies with 1.75" BS, along with my cobra 13" brakes,i know people have cleared these with spacers, what size spacer are you guys using to clear the brakes, im swapping to 3" studs up front just need to know spacer size, only going to run them down the track then pull them off for ride home,
any help would be appreciated, ive looked on search and found anywhere form 3/8, 7/16, to 1" spacer thanks in advance
ruger311 is offline
Old 01-13-2009, 10:32 PM
primetime5.0
primetime5.0's Avatar
according to the cobra guys they take a 1"
primetime5.0 is offline
Old 01-14-2009, 08:01 AM
ruger311
ruger311's Avatar
1" is what im figuring out, seems like you can run a 3/8" or 7/16" with a little grinding, but dont really wanna scar up my nice shiney red calipers,
ruger311 is offline
Old 01-14-2009, 08:34 AM
Portmaster
Portmaster's Avatar
Here is an idea that I used on my 03 that had a Cobra brake up grade. Instead of installing a 3 inch stud which will ugly up your OEM wheels. This spacer will get you out without swapping lug studs and center the prostars where a regular spacer wont. These bolt up and then the wheel bolts to the spacer. It's a much better alternative to putting on a 1 inch spacer on 3 inch studs that won't ever be able to center themselves. Just a thought. Worked great for me.
http://store.summitracing.com/partde...5&autoview=sku
Portmaster is offline
Old 01-14-2009, 08:46 AM
ruger311
ruger311's Avatar
ive seen those before,,, heard too many horror storys about them though, lugs coming off on them and lose wheel down the track
ruger311 is offline
Old 01-14-2009, 10:59 AM
Portmaster
Portmaster's Avatar
I never had a problem but I never ran them on the street other than back and forth to the track. I know a good many guys running them on the back of SN-95 car to widen out the track. I ran a set of 2.5 inch spacers made by Corvette Brakes so I could run a set of late model Corvette wheels on my Early Camaro. They were approved for Auto X. I've seen lots of problems with regular spacers where they split and the wheels would come off. Like anything else proper installation is the key.
Old 01-14-2009, 11:01 AM
ruger311
ruger311's Avatar
that is the truth man gotta install them correctly, i dont really care how the wheels look or what spacers i use i just know that i want it to be safe, im not going to run the skinnies on the street so not a problem there, thanks for the reply
ruger311 is offline
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
winner99
09-30-2015 07:04 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Prostar skinnies and 13" cobra brakes sn95 spindles
