Positive and negative in trunk
Old 01-31-2009, 06:31 PM
bmennen07
bmennen07's Avatar
Default Positive and negative in trunk
I need a postive +12, negative (ground), and brake light wire. Where are they located in the trunk and what color??
tryin to set up one of those led license plate frames. I grounded the black wire and I assume the positive is red? I spliced the red trunk wire but nothing.
thanks for the help!!
bmennen07 is offline
Old 01-31-2009, 06:51 PM
crusin92red5.0
crusin92red5.0's Avatar
you need to use a test light to find out what wires are hot(+). Pull off the panel in the trunk and follow the wires leading to the brake light.
P.S those liscense plate lights are ghey. if its the kind that i'm thinking of. i would rather have the color lights underneath the car than those.
crusin92red5.0 is offline
Old 01-31-2009, 07:27 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
You do realize if you're tapping the brake light wire it will only be hot when the brake is pressed right?
PRO50SC is offline
Old 01-31-2009, 07:43 PM
bmennen07
bmennen07's Avatar
yea the brake light just makes it illuminate.
lincolnshibuya
12-08-2015 04:37 PM
movielover40
09-15-2015 10:37 AM
unit91
09-15-2015 09:53 AM
TfcCDR
09-14-2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: Positive and negative in trunk
