Question about mass air flow
i was thinking about adding this with my factory fuel injectors..my car is far from stock..i just wanted to know would this be a better upgrade just to swap out my stock mass airflow for this one..i mean cause this new mass air has a bigger inside diameter..and i am running after market intake manifolds... thanks for the help....
http://store.summitracing.com/partde...084+4294783155
Unless you plan on going with bigger injectors for future modifications, I don't think upgrading the maf would really be worth it unless u need a new one calibrated for bigger injectors. It is a pretty minimal gain and has a negative effect on gas mileage.
I Highly Recommend the 76mm C&L MAF it would be a worthwhile addition to your combo and you can swap sampling tubes when you feel the need to change injectors I have had great luck with them.You can prob find one over on corral.net for a good price.
Luke9222
10-22-2015 11:55 PM
