wont revv high and backfire in intake when cold gets better when warming up
Old 02-15-2009, 08:01 PM
F150 StrokerCobra
F150 StrokerCobra's Avatar
Default wont revv high and backfire in intake when cold gets better when warming up
can i chek codes like the F150 truck the paperclip trick? ground the connector and count the chek engine lights?
and any ideas what may cuase this?
F150 StrokerCobra is offline
Old 02-15-2009, 08:30 PM
Catchpole
Catchpole's Avatar
Yea you can code check like that.
Catchpole is offline
Old 02-15-2009, 10:36 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Have you checked for vacuum leaks? I had the same problem you're describing and I found that PCV had come out.
ALMOST STOCK is offline
Old 02-15-2009, 10:56 PM
FORD TOUGH
FORD TOUGH's Avatar
Check for codes then let us know what you find.
FORD TOUGH is offline
Old 02-16-2009, 12:10 AM
jtirwin27
jtirwin27's Avatar
As far as high rev check for vaccum leaks or codes. Pop in intake is usually from timing. Bump #1 cylinder t.d.c. and reset you timing worked for me
jtirwin27 is offline
Old 02-19-2009, 09:03 PM
1989mustang5.0
1989mustang5.0's Avatar
mine did the same thing and mine was all in the timing
1989mustang5.0 is offline
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
J.casone400
09-12-2015 10:01 PM
kevsgt
09-09-2015 06:20 AM
09-08-2015 11:50 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: wont revv high and backfire in intake when cold gets better when warming up
