Newbie here having major problems
Old 02-19-2009, 10:32 PM
ViperblueGT
ViperblueGT's Avatar
it would seem to me to be a temperature related problem...
ViperblueGT is offline
Old 02-19-2009, 11:26 PM
symonds86
symonds86's Avatar
good point check yer fuel lines, make sure they are not to close to exhayst or any source of heat. it could be vapor locking
symonds86 is offline
Old 02-20-2009, 06:24 AM
Slow5o
Slow5o's Avatar
Thumbs up
okay i pulled the mechanical fuel pressure regulator off and blew threw it and i was able to drive the car for a good 20 minutes i shut the car off and then it did the same thing like the regulator is no opening up like it should im not sure of what the fuel pressure is suppose toe be going onto the carb.The only other problem im having is i have to jump the car off at the starter soleinoid on the fender i tried changing it but still did nothing with the key i just hear a click noise from the computer if anyone has had that problem it would be helpful to get that fixed as well im used to fuel injected 4cyl turbo cars lol so any information i get here i appreciate
Slow5o is offline
Old 02-20-2009, 06:36 AM
BlessedHellride
BlessedHellride's Avatar
Did you change the solenoid or the relay?
BlessedHellride is offline
Old 02-20-2009, 12:21 PM
Slow5o
Slow5o's Avatar
i changed the solonied on the fender that connects the battery to the starter where can i locate the relay for the starter
Slow5o is offline
Old 02-20-2009, 01:26 PM
ViperblueGT
The fuel pressure on a carb is pretty low like ten psi or so i was thinkin you should check somewhere around your gas tank like the pump is getting hot or somethin like that
Old 02-20-2009, 04:58 PM
jus4fun
jus4fun's Avatar
7 and 1/2 psi at max. Check to make sure your float levels are correct
jus4fun is offline
Old 02-22-2009, 11:03 AM
Slow5o
Slow5o's Avatar
how would i check the float levels on the car i know nothing about carbs
Slow5o is offline
Old 02-22-2009, 12:21 PM
Portmaster
Portmaster's Avatar
You guys are so confused it's confusing me, lol
Portmaster is offline
Old 02-23-2009, 10:49 PM
Slow5o
Slow5o's Avatar
okay narrowed it down as to be that the regulator is junk and im thinking that i need to do a pump swap to the v-8 pump but anyone know of a good regulator to run the carb on and have a return line set up for it as well
Slow5o is offline
11-18-2015 01:34 PM
Brett Ludlow
09-23-2015 06:59 AM
stangin1996gt
09-21-2015 11:01 AM
Quick Reply: Newbie here having major problems
