302 block ?
Old 02-24-2009, 04:14 PM
91 Fox 331
91 Fox 331's Avatar
Question 302 block ?
I just tore down my engine this past weekend and found that the number 1 cylinder has a nice score in it. My motor is already .030 over and i just dont know what the max is that a stock block can be taken out to. I was just wondering if I could take it past .040 because I know it would need to be.
If it comes down to it I will just end up buying an Iron Eagle block. But my only question about that is do they come pre-machined and ready for assembly.
91 Fox 331 is offline
Old 02-24-2009, 04:34 PM
BlessedHellride
BlessedHellride's Avatar
I took my old 83 model block to .060" over and beat on it for about 3 years N/A before it broke more rings and tore it down again.
BlessedHellride is offline
Old 02-24-2009, 05:32 PM
woodsy
woodsy's Avatar
It needs to be sonic checked now at its current bore size, then do the math to see how thick it will be on the major thrust side of the bore at 4.060. I have run many, many 4.060 blocks with no ill effects. No the iron eagle or ANY aftermarket block is nowhere near machined and ready for assembly. And if you are contemplating using your stock block, you certainly are not making enough steam to warrant an iron eagle block, unless 1500+hp is in your near future, and i will assume its not.
woodsy is offline
Old 02-24-2009, 06:30 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you can pick up a stock seasoned block easy for 100 beans..I've bought two in the past few years for such
mjr46 is offline
Old 02-24-2009, 08:09 PM
91 Fox 331
91 Fox 331's Avatar
i plan on pushin 15 to 20 lbs of boost to my motor and makin 750-800 wheel untill i get bored with that and want over 1000.
Old 02-24-2009, 09:22 PM
mjr46
mjr46's Avatar
subscribing^^^^^^^^^^^^
mjr46 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: 302 block ?
