SMOG PUMP
Old 02-25-2009, 06:41 PM
minnow81469
minnow81469's Avatar
Default SMOG PUMP
I got a 95 mustang gt and want to do an egr delete and a smog delete while my heads are out what do i need to get to make this happen
minnow81469 is offline
Old 02-25-2009, 06:50 PM
15austin
15austin's Avatar
The smog holes in the back of the head are threaded. Just screw a bolt in the hole. I believe it is a 5/8" bolt.
15austin is offline
Old 02-25-2009, 07:05 PM
minnow81469
and thats it thats all i got to do i was wondering if i had to pull the pump out of the car and replace it with something else
Old 02-25-2009, 07:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
cap the header port for egr draw off too
mjr46 is offline
Old 02-25-2009, 07:21 PM
minnow81469
how do you delete the egr cause i dont need it either im in the works of doing the smog delete and egr delete because i got a different set of heads
Old 02-25-2009, 08:58 PM
15austin
15austin's Avatar
You can buy a egr block off plate on ebay. Plug the port on the header. Take off the smog pump, get a shorter belt (smog pump delete bracket is stupid just get a shorter belt). Bolts in back of the head. Anything else Im forgetting?
15austin is offline
Old 02-25-2009, 10:48 PM
minnow81469
Yeah but figuring out what new size belt is needed is always a bea
Old 03-03-2009, 07:59 AM
maritimer95gt
maritimer95gt's Avatar
I'm going to do the same thing with the smog pump. I've got a 95 GT and I'm ready to rip the thing out. Does anyone know how big the belt should be?
maritimer95gt is offline
jwog666
12-27-2021 08:09 PM
Bokeo
10-10-2015 08:28 PM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: SMOG PUMP
