Suspension LX 5.0
Old 03-01-2009, 03:02 PM
xcp20000
xcp20000's Avatar
Default Suspension LX 5.0
Hello im new to these threads. I just acquired a 1990 mustang LX and it has lowering springs installed on it and it needs new struts. I have decided to replace the front struts and rear shocks. I have no idea what kind to get . I need some advice. When I drive the car and i go through dips in the roads the tires rub and that is one thing i would like to fix with this upgrade. any help would be greatly appreciated. I plan on ordering them today off the internet so hopefully they will be here by the weekend so i can install them saturday.
xcp20000 is offline
Old 03-01-2009, 03:13 PM
Tony71502
Tony71502's Avatar
Do you have any idea what kind of springs are on the car? Where are your tires rubbing?
Do you have stock caster camber plates? They are where the struts bolt onto the fender wells. It's pretty much mandatory that you get aftermarket caster camber plates with different front suspension parts. Otherwise the car will never be aligned correctly. That may be the reason for your tires rubbing...
What's your budget? I got some KYB gr2s because they are pretty cheap and better than stock. You should get some caster camber plates which are gonna be around 200, unless you have them.
Tony71502 is offline
Old 03-01-2009, 03:29 PM
xcp20000
xcp20000's Avatar
I have no idea. I think I want to replace pretty much all that stuff. including the springs. I was looking at this http://www.stangsuspension.com/store...?idproduct=408 and then later getting this http://www.stangsuspension.com/store...?idproduct=517 the maybe stage 3
xcp20000 is offline
Old 03-01-2009, 04:19 PM
wowvfast
wowvfast's Avatar
kyb are decent and fairly cheap....I have them on one of my stangs
camber plates aren't necessary unless you use coil-overs
wowvfast is offline
Old 03-01-2009, 04:33 PM
koesterca1
koesterca1's Avatar
100% Incorrect
koesterca1 is offline
Old 03-01-2009, 06:12 PM
Eight433
Eight433's Avatar
i have FRP 5300c springs which lowered the car about 1 1/4 or so. I did not get the caster camber plates and they had no problem aligning it, however the first time they set the toe a little too neutral so it wanted to follow every crack in the road with the 255/40/17 inch tires on it. I had them toe it in just a hair and once the new springs and poly bushings wore in, its much better. it was a bit of a handfull for a couple weeks though...
Eight433 is offline
Old 03-01-2009, 08:03 PM
xcp20000
xcp20000's Avatar
my car already has been lowered with lowering springs. can i just go to stage 2 and if i need stage 1 can i do that later?
xcp20000 is offline
baddog671
07-26-2016 01:20 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Suspension LX 5.0
