OTS cam choice, 308, 180cc prolines, track heat intake
Old 03-25-2009, 12:01 PM
ShadyZealot
ShadyZealot's Avatar
Default OTS cam choice, 308, 180cc prolines, track heat intake
For the sake of getting to the track quickly as the season is already amongst us i am holding off on this 347 and throwing a 308 together then i am getting from another member on here. Also picking up some proline 180 cc heads from him that have been worked a bit
Not worried too much about low end, just want to get as much ET out of the car as i can. Compression will be about 10:1
4.10 gears, 3500 stall speed
Already have a TFS track heat that i will be putting on it.
Will have a C4 behind it from redneck performance. Can get the convertre speced to the motor.
What do you guys feel would be a good OTS cam to go with?
ShadyZealot is offline
Old 03-25-2009, 02:04 PM
Sleeper_Stang_89
Sleeper_Stang_89's Avatar
Call comp cams or anderson and ask them, but the AFM N41 cam is good and the Comp Cams xe-282 worked pretty well.
Sleeper_Stang_89 is offline
Old 03-25-2009, 03:19 PM
Portmaster
Portmaster's Avatar
Comp Cams XE274HR
Portmaster is offline
Old 03-25-2009, 07:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
my xe 282hr worked okay, but you'll need a good stall
mjr46 is offline
Luke9222
10-22-2015 11:55 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Art161
09-09-2015 10:33 AM
vintageaion
09-08-2015 10:45 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: OTS cam choice, 308, 180cc prolines, track heat intake
