Msd Dist.
Old 04-05-2009, 10:07 PM
Foxbody87
Foxbody87's Avatar
Default Msd Dist.
Just got myself a new 6al ignition control box, Blaster 2 coil, and Pro billet distributor. My question is, I had a mechanic from a mustang shop tell me that I had a 50-50 chance of the distributor not working on my 5.0, can anyone tell me why he would say that. Or is he just blowing smoke...
Foxbody87 is offline
Old 04-06-2009, 07:58 AM
Portmaster
Portmaster's Avatar
If it's for a 5.0 and it has the hyd roller cam gear youll be fine. If you bought it new post up the part number. If you bought it used you can swap on a new dist drive gear in a matter of minutes. He's not blowing smoke but he's wasn't clear about why.
Portmaster is offline
Old 04-06-2009, 10:41 PM
Foxbody87
Foxbody87's Avatar
Yea i bought it new, believe the model is an 8456. Sayss it's specifically for my model, so not too worried, mainly just wondering why he'd say that, unless he thought i might have just gotten "a" msd distributor hoping it would work
Old 04-06-2009, 11:34 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
That distributor won't work any better than your stock one. Wasted money IMO. You'll be lucky if it lasts as well.
PRO50SC is offline
Old 04-07-2009, 09:28 PM
Foxbody87
Foxbody87's Avatar
Ok i appreciate the opinion, but what are you basing this off of???
Old 04-07-2009, 10:36 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I had one, it blew out the module in the first 2 weeks. The first time I was in the middle of a pass at the drag strip. I replaced the module and it blew it out again. I sent the distributor back to summit for a refund 4 years ago and have been running the stock one ever since w/ no issues. I'm not the only one that has experienced this.
G/L w/ w/e you decide to do.
PRO50SC is offline
Old 04-08-2009, 12:07 AM
Foxbody87
Foxbody87's Avatar
Alright, thanks for the explanation, i appreciate it
Old 04-13-2009, 12:55 PM
azazell64
azazell64's Avatar
haha funny you mention this I'm running the exact same setup and had the same problem as PRO50SC, with the exception that mine went the first time I took it out, and it works fine except when the car warms up, then it dies and has 0 spark, took the MSD out, put the factory back in, runs fine.
azazell64 is offline
Old 04-13-2009, 01:47 PM
grabbem88
grabbem88's Avatar
dang talk about bad apples here..in 8yrs i had one module go out,and my dads stock distributor went through 4 in 5 yrs..replaced it with my old stock one and never had any trouble..btw he has had his since new in 1989...he did have a few ignition/ground/electrical problems when the first one was in..after he did all the recall fixes,and my distributor at the same time<msd module was on it> who knows what actually happened or didn't happen.
grabbem88 is offline
firehorse02
11-16-2015 11:28 AM
JonnyBlazeGT
11-03-2015 01:10 AM
jc1
08-29-2015 07:09 PM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: Msd Dist.
