Valve Grinding
Old 04-06-2009, 08:03 PM
redmustang83596
redmustang83596's Avatar
Default Valve Grinding
So I am grinding my valves and I cant really find any specs online. I need to know the valve face angle, and the valve seat angles for the intake and exhaust valves on a Trick Flow Twisted Wedge Track Heat (the new street/stip heads I believe are the same thing) head. The intake valves are 2.02" and the exhaust valves are 1.60". Any help would be great thanks.
redmustang83596 is offline
Old 04-06-2009, 09:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
call trick flow
mjr46 is offline
Old 04-07-2009, 12:30 AM
redmustang83596
Originally Posted by mjr46
call trick flow
ehh i could.. butttt maybe someone will chime in
Old 04-07-2009, 07:02 AM
Portmaster
Portmaster's Avatar
IIRC it's 37-45-52 on the seat and 45 on the valve. Do the 45 degree primary on the valve and then a 30 degree back cut. Sometimes you can improve flow by changing the backcut angles just a little but but that would depend on the head and you would need a flow bench
If you have the head in front of you and you can't figure out the valve angle you might want to reconsider this move.
Portmaster is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
svfetter
10-05-2015 11:39 AM
KingRando
10-02-2015 08:06 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Valve Grinding
