Turbo on my 86 mustang
I have an 86 speed density 5.0 and i would like tp know if i am going to have any problems when i put it on .My current mods are an edelbrock intake manifold ,gt-40 heads ,mac headers ,255 fuel pump 75 mm t/b and spacer .i would like to know if anybody has a turbo on a speed density car .thanks for looking
you could do a turbo on speed. but your never going to find the gains that you will with maf. for a couple hundred bucks its the best thing your ever going to do. its like, does a plumber not bring his monkey wrench when changing a pipe......
the problem you'll run into is with realatively a low amount of boost, you'll max out the duty cycle on the 19 lbs inj, you have two options, 1 maf conversion and get the proper maf for a boosted application and whatever injectors you'll need for the amount of boost planned or purchase a stand alone tuner for speed density so you can change the injectors
NorthAmericanTuning
03-18-2016 11:21 AM
